Results 1 to 5 of 5
    VXRed silverswish's Avatar
    14th August 2012
    121
    Angry Coolant/Overheating Issue
    Hi all,
    So my car has been overheating lately, each time the coolant bottle loses all coolant and is empty.
    No white mayo under oil cap
    No obvious leaks under car
    Only losing coolant under pressure, when engine is running
    So my question to you is, where on earth is my coolant going?
    Star Silver Astra VXR (2006) - Black 19" alloys
    17,618
    Could be leaking by the water pump
    Could be leaks in the radiator
    Could be a leak in the turbo water line.
    Check these areas. I happened to have 3 leaks all at once, the radiator, the turbo line and the line by the water pump
    6th February 2008
    15,968
    Get a pressure test done on the cooling system, you will see where the water is escaping.
    17,618
    If its only leaking under pressure i'd definitely be looking at water pump. I know it's a different car but our mk7 fiesta had a really annoying leak which only occurred after a drive when it had all been pressured up, couldn't find any drips from any of the pipes. Turned out the water pump was goosed.
    3rd May 2015
    1,034
    If the cap has ever been over tightened it damages the inner cap seal and can cause head gasket faliure.
    Full 3" Piper turbo back, Airtec fmic, piper x cone, Dap r springs, tarrox g88 discs, EBC yellow pads, powerflex engine/gearbox inserts + rearbeam bushes, whiteline lower arms, vredstein ultrac vortis,courtnay retainers, turbosmart actuator + recirc. Courtnay sport stage 3 mapped.
