Results 1 to 10 of 10
    15th June 2018
    3
    Default How to adjust clutch
    Hey all!
    I was wondering if it is possible for me to adjust the clutch a bit on my Astra? It doesn't respond until it's gotten rather high up in my opinion so I wanted to adjust it.
    I have what I believe to be a 2007 Vauxhall Astra VXR, around here it's called an Opel Astra OPC.
    I used the search function but didn't seem to find exactly what I was looking for.
    18th February 2007
    51,626
    From memory I'm sure they are self adjusting?
    Astra
    22nd April 2017
    72
    The clutch is hydraulic, there is no adjustment
    17,913
    Maybe it's worn?
    15th June 2018
    3
    Quote Originally Posted by Carlmu View Post
    Aw man in that case do I have any options? It really does feel quite high and i hate using it when stopped in hills and stuff..
    17,913
    Maybe just have to adjust to it mate. You'll get there.
    18th February 2007
    51,626
    Quote Originally Posted by Powerline View Post
    Buying a new one to replace a worn one is your only choice really
    Astra
    15th May 2013
    17,916
    Sounds knackered. Similar to my Type R when I bought it. There is adjustment on those but I went for a replacement and it was all good.
    Make sure it you are going to replace it you budget for a new Dual Mass Flywheel too. If you have just the clutch done you'll kick yourself at a later date if the Flywheel decides to fall to bits
    15th June 2018
    3
    Right then, seems my options are to either work with it the way it is or buy a replacement, guess i'll check prices and then make a decision, i appreciate all the fast responses everyone!
    18th February 2007
    51,626
    Best of luck with it
    Astra
