Results 1 to 10 of 14
    VXRed blooded Steveh24's Avatar
    12th October 2012
    364
    Default Header Tank Sensor
    For the past week my header tank level warning light keeps coming on after 20 mins or so even though there is no water missing, my mechanic is fairly certain it's the sensor which I tend to agree with, but does anyone know where the sensor is or what the part number is or even a picture would be good.
    26th February 2012
    1,772
    12th October 2012
    364
    No this is not it, my tank is black metal
    Are you VXR enough?
    28th September 2009
    984
    It will be the sensor, mine did the same thing. Let me see if I can find my old header tank with the sensor in it
    12th October 2012
    364
    This is my header tank
    Are you VXR enough?
    28th September 2009
    984
    Sensor is visible on the pic you sent... The electrical connector just underneath. It twists a bit one way to remove it.
    I can't see any part numbers on the sensor. My new header tank came with the sensor in it so I hope it's not just a part that comes as a bundle with header tank.
    Are you VXR enough?
    28th September 2009
    984
    Are you sure nothing is leaking? The tank looks like it's had fluid or something dripping down it at some point. Check on the downpipe heatshield aswell since it looks to have some sort of yellow stuff on it below the shape of the header tank.
    Is it filled to the cold level when cold? The yellow tab, stupid design having a black bottle.
    VXR enough Jon1796's Avatar
    24th August 2015
    1,597
    http://ecat24.com/opel/catalog/part/...29/4213/41312/
    Think you have to get whole thing ?
    It’s underneath !!!
    12th October 2012
    364
    Thanks for the help guys
    The two top hoses had become very soft and one was leaking, which is why you can see coolant over the tank, but both hoses have now been replaced.
    The tank is full which is why it likely to be the sensor that's at fault, although now I know where it is I will undo it, clean it and put it back and see if that solves the problem
    VXRed blooded Finn67's Avatar
    4th November 2012
    319
    Spot on Jon - You can't get them separately (Thanks Vx) you have to buy the whole bloody lot !!!!
