Results 1 to 10 of 15
    22nd June 2018
    4
    Default Need advise please
    Hi guys my 2 front shocks need replacing on my vectors vxr for £330 each!! It’s gonna be cheaper and more efficient to get coil overs all round but I have sensors on each corner, any ideas to bypass this pain in the backside? Your opinions will be greatly appreciated 👍👍
    22nd June 2018
    4
    Vectra!! Also it revs high and misfires, would that be down to a dodgy air mass meter?
    VXR enough Jon1796's Avatar
    24th August 2015
    1,701
    Front dampers
    https://r.tapatalk.com/shareLink?sha...3&share_type=t
    24th August 2015
    1,701
    Revs high when you start or all the time as choke will kick up 1500 then drop slowly down. Missfire most likely coils and plugs. If you’re really unlucky Ecu or chains.
    You can turn ids off with t2 or oc.
    6th February 2016
    63
    I replaced all four of mine with genuine ones supplied by Courtenay. Hundreds cheaper than getting them from Vauxhall because Courtenay get them from Opel and bypass the Vx dealer markup.
    11th July 2014
    366
    if you want to get rid of IDS consider Bilstein B8 shocks with Eibach or H&R springs from these guys www.tuningteiletotal.com
    22nd June 2018
    4
    Nice one, I know it revs high when choke is on but it happens whilst slowing down changing down gear and sat in traffic, deffo gonna check them coil overs out when I get in, and for the miss fire hopefully nothing serious 👎👎 so I will get it checked out
    6th February 2016
    63
    They do hang on to the revs between changes. They need a deliberate lifting of the right foot before you push the clutch in, like earlier than you would in most cars. But if she's racing in traffic it's likely a broken vacuum pipe at the back of the engine. Take the cover off, run the engine and if there's a leak back there you should be able to hear and feel whooshing. I found a one-way valve had broken, really cheap to replace from Vauxhall. Then when I did the plugs the other day I took out the fuel evap valves (I think that's what they are, cone shaped plugs in the back of the inlet manifold) and found one of the little o-ring seals on the end was shot. Replaced both with seals from a Halfords box set and she now idles better than ever.
    VXR enough V6spike's Avatar
    18th May 2013
    1,849
    Misfires are usually down to plugs and coils, try plugs firs and if its been remapped then should be 0.7/0.8 depending on plugs. Standard NGK ones are fine as are Denso IKH 24's. coils are pricey so need to be sure first.
    it will hunt on idle as well which is normal, though too much and it could be fuel rail/injector related. if the EML light comes get the codes read first before clearing and post them up here or google them.
    As above, the vac pipe are pretty week so be careful when changing plugs. you can sometimes hear a leak but a decent torch and mirror on the pipes will help. if you find broken pipes the easiest thing to do is change them for silicone hoses, also the plastic one way valves can be replaced for a few quid with alloy ones. much sturdier.
    Are you VXR enough?
    28th September 2009
    991
    Quote Originally Posted by V6spike View Post
    Sorry to jump in, don't suppose you have an example of the alloy one way valves? My vacuum pump goes off every morning for up to 5 seconds so i'm losing that vacuum somewhere until its charged it again so I think a one way valve might be goosed. Going to replace all the plastic with silicone and the one way valves too. Do you recall how many there are off the top of your head? Might save me a little bit of time going out to count things up :-)
