Results 1 to 10 of 12
    VXR newbie samr7's Avatar
    24th March 2017
    5
    Default Navi 650 audio streaming
    Got a Navi 650 on 64 plate Bluetooth calling/voice control works but can’t stream music from a playlist yet if someone sent me a video eg YouTube (via sms message) if I open and play it in car audio plays through my speakers? Really confused/does this need updating? Or just not possible on 650
    Thanks Sam
    VXRacing ahead
    26th April 2014
    607
    I've got a navi 650 on a 14 plate , mine doesn't support voice control, or audio streaming via BT. I have to cycle trough the address book ,using the control.The navi 950 IIRC supports this.
    24th March 2017
    5
    Quote Originally Posted by Mrs S Cat View Post
    Thank you, absolutely mental how many variations I read from system to system...don’t suppose you know if the 950 can be straight swapped into it? Little concerned with all these variations wiring must vary as much.
    Thanks again Sam
    VXRed blooded vocky's Avatar
    5th April 2015
    297
    Have a word with Rusty on vxoc site, he should be able to upgrade your Navi 650 to a Navi 950
    VXRacing ahead
    26th April 2014
    607
    I'm not entirely sure, but assuming all the looms are there , should be ok. I think you need to detach the old one from the car, and attach the new one via tech 2 or later, someone else here should be able to confirm this. Also i think it just a software for the voice control as if i press and hold the button on the steering wheel it comes up language not supported..
    I don't think the 650 supports ad2p streaming at all , but this does
    https://www.car-vision.co.uk/astra-j...431020232.html
    But you lose voice control which we don't have anyway!
    I just use a usb flash drive for audio , its 64GB(1/2 in long) and holds a shed load of music , all controlled via steering wheel.You can't even see it through the windows.
    VXRacing ahead
    26th April 2014
    607
    Manual here if you need it:
    https://www.car-vision.co.uk/en/faq#faq_1
    24th March 2017
    5
    Thx
    24th March 2017
    5
    Thx
    VXR enough FreshDriver's Avatar
    8th April 2008
    1,300
    Not possible.
    30th August 2018
    1
    I have the same problem, I just bought an gtc vxr with the Navi 600 without reading up about it, is it possible to get Bluetooth audio streaming? I use Spotify on an iPhone8 and reading all these forums about the issue is ball bursting, could you swap out the whole 600 unit for a newer spec unit that does support? Without too much wiring issues?
