Page 3 of 6 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 51
  1. #21
    VXRed Nasir's Avatar
    20th June 2016
    99
    Looking at my car again it is directly underneath the clutch pipe, is that a connector in your second photo?
    Sent from my ONEPLUS A6003 using Tapatalk
  2. #22
    9th February 2018
    878
    Yes mate it seems it could be disconnected but no idea if that's it, is that my clutch pipe next to it ?
  3. #23
    20th June 2016
    99
    Looks like it to me mate, without actually looking at the car I couldn't 100% confirm it though. If that is a loose connector that could be the problem, the actual switch should be further down, below where the clutch pipe is.
  4. #24
    20th June 2016
    99
    I should have made an arrow rather than a line, the top of the yellow line is where the switch is
  5. #25
    9th February 2018
    878
    thankyou for taking the time to post that pic i think ive found it , its behind a a pipe that im guessing id have to take off , i can move the pipe abit with my hand
    does that white clip just unclip mate ? or does the whole nut come out ?
  6. #26
    20th June 2016
    99
    You can unclip the sensor connector, pull the white tab back and it should allow you to pull the connector off
  7. #27
    9th February 2018
    878
    Ok unclip sensor connector then replace the part with nut and see if light starts working the nut gonna be tricky to get off without removing pipe but I'll give a go, just gotta buy part first
  8. #28
    20th June 2016
    99
    I would bridge the sensor connector first, get a bit of wire and join the 2 pins of the connector together and then see if the reverse light works. If it still doesn't work then in theory the switch should be okay
  9. #29
    9th February 2018
    878
    Ok bridge... turn ignition on then hope it comes on as then that confirms I need this part.
  10. #30
    20th June 2016
    99
    Yeah that's right mate, let us know what happens
