Results 1 to 10 of 11
    18th April 2016
    181
    Default Thinking about forging my j
    Has anyone done this is it worth it???
    6th February 2008
    15,926
    Have to ask why are you thinking about forging.
    Standard engine or do you want to get to x bhp
    VXRed vocky's Avatar
    5th April 2015
    214
    all you really need is the pistons and steel rods from zzp in the states. Plus a head gasket and head bolts from Autovaux.
    The bottom end should then be strong enough for 500bhp or so.
    Just remember your turbo will run out of puff, so will need upgrading, you will also need a 3" exhaust to allow that to flow better and a strong clutch.
    If the engine is low mileage you can even fit the rods and pistons with the block in the car. Just whip the cylinder head off.
    Is it worth it = if you have deep pockets and want good power then probably, but longer term probably not - you will eventually sell the car and make a loss.
    18th April 2016
    181
    Well Iím currently running wg stage 2 power double decat next thing is a front mount but I donít think the power will be massive than after that itís like do I go for it.realisticly how much we looking to get around 450 bhp?
    5th April 2015
    214
    not many companies offer the service, but WG should be able to help.
    Parts:
    pistons are $500 + shipping + import duty = roughly £500
    https://zzperformance.com/ecotec/wis...ed-lnf-pistons
    rods are $450 + shipping + import duy = roughly £450
    https://zzperformance.com/ecotec/eng...onnecting-rods
    Head gasket and head bolts should be less than £100, buy genuine as they are usually cheaper than pattern and better quality
    Turbo - depends what you want or whats available
    Exhaust - as above
    VXRed blooded Klystron's Avatar
    2nd June 2015
    481
    If your going for that much power, could need an uprated clutch, radiator, and the inlet will need changing.
    18th April 2016
    181
    Quote Originally Posted by Klystron View Post
    Running the wg stage 2 clutch and fly pal , seriously considering it...surely seeing them figures Iím looking around £7/10k
    6th February 2008
    15,926
    £4.7k just for the turbo on stage 5, gives you 400-420 bhp - shop.wgmotorworks.co.uk/index.php?route=product/product&path=115_124_197&product_id=468
    6th February 2008
    15,926
    No one has mentioned upgraded brakes - no point increased power if you can not stop
    2nd June 2015
    481
    AP racing 362mm, like this, AP racing 6pot -£2500
    http://www.vxronline.co.uk/forum/sho...progress/page2
