Page 3 of 3 FirstFirst 1 2 3
Results 21 to 25 of 25
  1. #21
    VXR enough R34nel's Avatar
    17th May 2009
    2,549
    Quote Originally Posted by R15VXR View Post
    Heyup, longtime no see.......
    I think thats pretty impressive for a std VXR with a uprated cooler ( esp in this heat ) .... forget about the bhp, matters not, its the torque that counts and is impressive
    IMO the exhaust is NOW holding you back and would take you to 300/340 however as its a custom map once you have a proper full system on you would need to go again to be retuned
    Hi mate, it’s stage 2.735745837268, just the 2nd cat to be a stage 3
    Stage 3 Arden Astra gone
    Stage 2 burg
  2. #22
    17th May 2009
    2,549
    Quote Originally Posted by DanMc View Post
    Had mine done at RnD, milltek catback with TX autosport cat and downpipe, Airtec cooler and mine had the CDTI box with standard filter. Made 291 bhp and 344 lb/ft torque
    What’s the tx pipe you bought, do you have a link
    Stage 2 burg
  3. #23
    17th May 2009
    2,549
    I’m suspicious the problem is the turbo, tested again tonight unplugging the boost reference to the actuator and it only sees 16psi, the actuator is basically doing nothing on my engine, I would expect boost to fly up into the 20’s with the wastegate closed, I read about someone saying they bought a cheap turbo cartridge (chra) and could only achieve low boost...I am just speculating though
    Stage 2 burg
  4. #24
    17,913
    Quote Originally Posted by R34nel View Post
    Strictly speaking stage 2 is full turbo back system which is your biggest power gain. You're a kind of hybrid stage 1.5 with hints of stage 3 in the mix
  5. #25
    17th May 2009
    2,549
    On my first Arden I had the same setup as now but with dreamscience map and it did 283, 289 and 299 on different dynos so I figured I could save my self 400 quid on the second cat section, like I say even with wastegate held shut it won’t make over 16psi and it won’t hold that for long so I think that’s where the main problem is
    Stage 2 burg
