Results 1 to 8 of 8
    VXRed blooded Rksmith's Avatar
    15th December 2016
    493
    Default Inspection of turbo!!!
    Hi guys
    So I was in the middle of changing the clutch and all of the shabang that goes with it. And thought Iíd inspect my turbo at same time.
    Now I have a little play UP and DOWN not very much I have to say but I have a lot of play IN and OUT is this a bad sign the fins look mint no damage on them and all and all dry.
    Question is if it needs replacing I was thinking just replacing the core inside what do your guys think about doing this donít want to pay for new turbo tbf
    Any advice would be grateful (spesh if someone has done this before and would like share there results) thanks.
    VXR enough Ant21's Avatar
    29th September 2013
    1,507
    How much is a lot? A mm for example or more? Does the turbine touch the casing in anyway? If not it shouldn’t be a problem.
    They will move ever so slightly from new as that’s the tolerance allowed to let oil flow and effectively float the shaft.
    15th December 2016
    493
    How much is a lot? A mm for example or more? Does the turbine touch the casing in anyway? If not it shouldnít be a problem.
    They will move ever so slightly from new as thatís the tolerance allowed to let oil flow and effectively float the shaft.
    Definitely more then a mm on the IN and OUT check. Iíd prob say 1-2 mm on UP AND DOWN check.
    Turbines donít touch casing and spins quite freely.
    13th May 2008
    21,632
    Quote Originally Posted by Rksmith View Post
    Hi guys
    You could contact AET in Yorkshire or better still Owen Developments and ask how much to upgrade to a k04h ( Hybrid ) !?
    No point buying brand new ......
    15th December 2016
    493
    I noticed yesterday underneath the wastegate flap inside thereís a slight crack going down is it shagged?
    15th December 2016
    493
    So is this a new turbo job?
    10th June 2015
    143
    Does your car perform differently when cold as to when hot as any leakage of boost may change when the turbo is hot and the metal expands and closes the crack.
    15th December 2016
    493
    Quote Originally Posted by d fry View Post
    No different but is weak tbf mate
