Results 1 to 4 of 4
    14th October 2017
    7
    Default Best all around disc and brake setup?
    Hi guys need some advice on discs and pads for my 2010 corsa vxr. What is the best all round setup/ kit to buy for a reasonable price? Cheers xx
    VXRacing ahead Euro's Avatar
    7th November 2011
    658
    Probably the burg / Club Sport ones? But you would probably need to change to their suspension and wheel size?
    30th December 2014
    1,548
    Quote Originally Posted by cooldude2284 View Post
    If your after a bigger brake setup then go for the burg/clubsport setup.
    If your just after replacements id recommend a full Pagid discs and pads setup, just fitted it on mine and they are spot on.
    6th May 2017
    675
    Depends what you are using the car for, i.e. road, track or a bit of both.
    I recently changed my discs and pads all round and got the lot for £153 delivered in 2 days!
    I went for an OEM equivalent for the discs (road use only) and brembo pads. Very happy with them, but for track use you would be better getting something a bit uprated.
    The place I used was brake depot 01246 281543 they are also on eBay, prices are the same direct.
