Results 1 to 6 of 6
    7th July 2018
    4
    Default Rim and tyres rubbing on shocks
    I got a 2012 Nürburgring editon completely standard wheels ect but for some reason the left passenger side rim is scrapping and rubbing on the shock absorber and I can hear a knocking noise when going left and right from that side as well I took it to a garage and they said they can’t see anything and advised putting 5mm spacers on...is it really safe to do so and anyone have any ideas what it could be?
    31st December 2014
    1,576
    Quote Originally Posted by Reecez97 View Post
    If its all standard then spacers should not be needed.
    If its knocking it could be a drop link or broken spring, a broken spring would explain why it would be rubbing as it will be lower.
    7th July 2018
    4
    I’ll have to get a second opinion the wheel is also slightly buckled could that have something to do with the rubbing on the shock but it’s also worth saying there’s still the knocking noise when turning left and right when stationery
    VXR enough yodacraig's Avatar
    25th January 2010
    3,058
    Sounds like a broken spring to me even if you had a buckled wheel it wouldn’t rub
    xbox addy -turboyoda85
    Instagram yoda_craig85
    VXR enough Minismithy90's Avatar
    28th July 2010
    1,807
    I’d say broken Spring.
    Fiesta Mk5 ZS>Fiesta Mk6 ST>Clio 172>Astra 'H' VXR>Fiesta Mk7 ST>Corsa 'D' VXR Nurburgring
    VXRed Noxious89123's Avatar
    22nd June 2014
    169
    The only part that could rub the wheel would be the broken spring itself; the wheel should never rub the body of the shock, even with the suspension fully compressed. Ie, even with no spring fitted at all and the car sat on it's ****, the wheels and suspension shouldn't collide.
    Sounds to me like something might be damaged or bent.
    Astra GSi ~ VXR Injectors / VXR 80mm AFM / VXR Turbo / CDTi Airbox / TS Recirc / K&N / 3" Piper Exhaust / CS FMIC / EBC YellowStuff / Bridgestone S001 / Bilstein B12 Pro-kit / Whiteline RARB
    CS Mapped 285 BHP / 340 Ft.lbs
