Results 1 to 10 of 12
Thread: Smoke
    VXRed VXRrich1992's Avatar
    21st October 2017
    45
    Default Smoke
    Hi all not sure what's happening with my car I've done a pre cat delete still got the second cat and a cat back non res when the car is left idling for awhile and then when you rev the car a little puff of smoke comes out then it doesn't do it again until it's left idling again the turbo still sounds strong and the car pulls like a train wondering if it's the second cat maybe blocked?? Thanks all
    Regional Assistant - Scotland West f1slikki's Avatar
    20th May 2009
    1,491
    Sounds like stem seals need doing
    Arden Astra H VXR/Stage 2/6k Afl's/19"Gloss Black Alloys/Powerfold Mirrors/Sight & Light Pack/Parking Sensors/Keyless Entry,Start/Full Remus&Oil Restrictor Bolt By Jigger/Blue,Red SMD By Stampede/Drilled & Grooved Discs/Tints/Green Cotton Filter/Carbon Iinlays/VXR Grill Badge/Private 3D Gel Carbon Plate/Team Hekos/Stubby Bmw Ariel/Debadged//Indicator Surrounds/C,C Bootstrip/Led Side & Plate Lights/VXRO Stickers/
    20th January 2014
    2,153
    First important question; what colour is the smoke? Blue/black/white?
    Might be coincidence, but have you an oil restrictor bolt installed since you did the precat delete and catback installation?
    OPC ÉIRE- Drop me a PM for Irish meets, group adds etc.
    21st October 2017
    45
    White????
    20th January 2014
    2,153
    White is a sign of moisture/coolant escaping the exhaust.
    Not a whole pile of moisture in the air of late to be condensate from the exhaust.
    Usual easy check is for mayo (white residue) on the underside of the oil cap, or traces of coolant level dropping.
    You didn't sound sure though. May need another check?
    21st October 2017
    45
    No no it's white I've checked the oil cap and that was fine I did notice the coolant is going down but not much
    VXR enough chodiddly's Avatar
    12th December 2015
    1,647
    do u get a puff of smoke when pulling off from traffic lights?
    21st October 2017
    45
    Yeah only if it's been sat for a couple minutes
    12th December 2015
    1,647
    yea mine did the same....sounds like stem seals to me theres a place in birmingham (depending on your location) that is well known for repairing them from what ive heard not a bad price either.
    21st October 2017
    45
    That's the other problem I live in the isle of man
