Results 1 to 6 of 6
    Are you VXR enough?
    28th September 2009
    944
    Default Vacuum Leak / Vacuum pump starts every morning
    Hi all,
    Does anyone have an in depth knowledge of the brake vacuum system on these things?
    The vacuum pump is going off every morning for up to 5 seconds which it never used to and its looooooooooooooud when its doing it. On an evening it might only do it for a second or two so I know its losing the pressure somewhere.
    I'm pretty sure this makes the car sluggish to set off as the last time it happened it was the pipe down to vac pump, replaced that and the sluggishness went away (as did the pump noise).
    So far I've replaced the pipework from vac pump up to brake servo, pipe work from brake servo that goes to the Venturi fitting and plenum. The Venturi fitting was replaced when I did the chains quite some time ago (not sure how common these are to have the one way valve leak?).
    Does anyone else know where needs to be looked at with these? There are one way valves in all this pipework which I've checked and replaced as a precaution which potentially only leaves the Venturi which is an expensive part to replace again for what it is and it can't just be removed without high risk of snapping its connectors that hold it into the covers.
    Not sure on the best way to troubleshoot this thing? Any ideas welcome, its driving me crazy .
    1st August 2016
    311
    Maybe the pump its self is worn as they all do it some quietly some nosily
    Vectra VXR estate 07
    Are you VXR enough?
    28th September 2009
    944
    Not sure, it never used to do it this often and I've always been able to hear the pump since I got it. Got one more one way valve to replace to see if it helps.
    It seems to lose all its pressure overnight. There was a time when it held it for quite some time and the pump hardly had to do anything on a morning. The last time it did it I seemed to lose the sharpness of acceleration when pulling away. Sorted that out with new pipework and now it's back to the same thing... Sigh.
    6th February 2016
    63
    Mine does this too ever since i replaced the one-way valve, but it doesn't have any effect on performance, just sounds like a steam train for a few seconds in the morning. Actually much quieter since I replaced the little 0-ring seals on the two plugs in the back of the plenum. Might be worth doing if you haven't already, as it's a few pence for the seals.
    VXR enough V6spike's Avatar
    18th May 2013
    1,739
    Quote Originally Posted by WeAreBorg View Post
    Where did you get o rings mate
    6th February 2016
    63
    In a box of assorted sizes from Halfords. I did ask at Vauxhall and they don't sell the o-rings separately, you have to buy the whole unit!
