Results 1 to 3 of 3
    4th April 2016
    9
    Default Rear diffuser removal
    Got into a bit of an accident resulting in rear diffuser is not sitting flush any more.
    Anyone know how to remove it without taking off the rear bumper? Tried searching but only found some vague instructions.
    Any help would be greatly appreciated!
    Are you VXR enough? Nurburgring 223's Avatar
    16th May 2012
    911
    I did mine years ago mate, was fairly easy! Just remove the screws (cant remember how many) and gently pull
    Astra VXR GTC, Summit White, Aero Pack, Performance Seat Pack, AFL's, Sat Nav, Climate Control, Tints! SOLD
    VXRed blooded imac's Avatar
    27th July 2015
    485
    on the J there is 6 pop pins underneath the diffuser , one at each end, 4 in the centre area , push the pins through, pull the plugs out. from the back off car start from one edge and gently ease the diffuser away , use a flat blade along the top finding the clips and gently press to release , easy job .
    mac
    BUZZ BLUE GTC VXR mid life crisis & loving every minute.
