Results 1 to 10 of 13
Thread: Brake Upgrade
    13th February 2018
    88
    Default Brake Upgrade
    Iím looking at upgrading the standard brakes I thought green stuff pads and grooved discs, whatís everybodyís thoughts?
    18,147
    Personally i'd say Don't bother mate. At best get some braided lines if yours are old and stick to oe pads and discs.
    Every "upgrade" I've experienced with grooved discs etc made brakes feel less responsive. The standard brake pads are made by ferodo so they're good stuff.
    The only real upgrade is bigger discs and calipers.
    20th January 2014
    2,163
    A full bleed of the brake fluid can make all the difference to the feel of the pedal also. Ideally it should be bled every 2 years/with a change of pads.
    Along with the brake fluid, bleed the clutch line as that also holds moisture laden brake fluid coming from the master cylinder.
    How do you find the brakes at the moment?
    18,147
    Quote Originally Posted by VeXeR View Post
    I'd love to give my front brakes a good bleed. But I don't trust those bleed valves and the p155 soft metal of the calipers around them.
    13th February 2018
    88
    They are ok to be honest I might just put oe back on need doing though because on the backs the pad isn’t using all the disc and might just do braided hoses.
    Cheers guys
    20th January 2014
    2,163
    Rust remover overnight directed at the thread, dry the hex in the morning, good socket head over the bleeder with a hammer ready to smack the wrench end to shock it open. Well worth a try even on the hub. Worst case scenario; vice grips and blow torch.
    OPC …IRE- Drop me a PM for Irish meets, group adds etc.
    18,147
    No blow torch. Rubber line in the vicinity ...
    20th January 2014
    2,163
    Chances are you won't need the blow torch.
    Rubber lines can be shielded with aluminium foil plus some insulator
    VXRacing ahead tye_time's Avatar
    24th February 2017
    622
    These are on my wishlist:
    https://www.ebay.co.uk/itm/Wezmoto-B...19.m1438.l2649
    I will be sticking with normal pads and discs - although saying that i might be tempted to try a different brake pads for less dust! I'm planning on flushing my brake fluid soon - bleed nipples are a worry, but with plenty of plus gas and gentle taps of the hammer they should come out ok.
    18,147
    Quote Originally Posted by tye_time View Post
    Just have a page open on your phone on a new caliper from eurocarparts just in case
