Results 1 to 3 of 3
    VXRed blooded Steveh24's Avatar
    12th October 2012
    365
    Default Lambda Sensor Connection
    Can someone tell me where the connecter is for the Vectra VXR Lambda Sensor 1 Bank 1 is located.
    Mine was unplugged as the sensor was causing running problems and I've now replaced it, but can't see where the connecter plugs in behind the bulkhead, the length of cable dictates the rough area it goes, but I've looked with a torch and can't see an empty socket.
    A picture would be really good.
    Are you VXR enough?
    28th September 2009
    988
    I guess you got this sorted?
    12th October 2012
    365
    Yes eventually found it, thanks for asking
