Page 3 of 3 FirstFirst 1 2 3
Results 21 to 26 of 26
  1. #21
    18,147
    Did you shake it up enough? Were the conditions too cold?
  2. #22
    9th February 2018
    878
    temperatures were ok , was in a warehouse . i did shake vigorously but maybe it was that , cheers i think ill clean it and respray the lacquer and see what happens
  3. #23
    18,147
    Another alternative wait til it cures then just polish it to restore the gloss.
  4. #24
    9th February 2018
    878
    Yeah maybe, I'll see how it looks tomorrow and decide
  5. #25
    4th July 2017
    17
    I didn’t think that we have here ******* but apparently I was wrong!
  6. #26
    20th January 2014
    2,163
    Quote Originally Posted by tomerzhr View Post
    Hello,
    On my vxr 2014 I had a vibration at the gas pedal.
    The vibration itís like buzzzz not like the car shaking.
    Its happening between 80-100 kmh speed!
    I was checking the driveshaft both side.
    The lower gear mont and made wheel balancing and all fine, but still
    Vibration.
    I also removed power flex insert in the lower mint and it
    Didnít help.
    The steering wheel not shaking while itís happened
    The vibration is on the gas pedals.
    Any ideas?
    Might be at a certain rpm under a certain load?
    Remove spark plugs, compare the porcelain insulator colours. Upload pics in order from cylinder 1-4.
    Could be as simple as plugs/coilpacks.
