Results 1 to 3 of 3
    VXRed seanaldo1987's Avatar
    20th July 2017
    51
    Default H&R Cup Suspension??
    Hey folks,
    Anyone on here running or ran the H&R comfort cup kit before?
    Currently running H&R 50/40 springs with stock dampers and found this kit for much cheapness as i was looking to move to an uprated damper to run with my current springs. The kit comes with the same springs i currently run and obviously the dampers to suit.
    Will running the H&R dampers as oppose to the stock damper change the ride height of the car...... as i am already tight on clearance as i run 225/40 tyres on my 18s
    Thanks in advance
    Arden Corsa VXR
    Scorpion double decat, Remus backbox, AEM Cone, Courtaney intake & boost hoses, H&R Cup kit
    23rd May 2013
    2,461
    Quote Originally Posted by seanaldo1987 View Post
    Hey folks,
    Thanks in advance
    No, strictly speaking its the springs that determine the ride height.
    That said you'll probably find the car sits slightly higher with the new kit on as none of the components will be tired.
    20th July 2017
    51
    thought that would be the case.
    guessing there will also be a marked improvement on how the car rides and handles as the current dampers are designed for standard springs
    Arden Corsa VXR
