Results 1 to 3 of 3
Thread: New VXR Owner
    31st July 2018
    1
    Default New VXR Owner
    Hi all,
    I'm picking up a 59 plate saloon in Arden blue tomorrow. Its covered 52k miles. I'm looking for some tips on what I should get serviced?
    Peter
    VXRed Andre's Avatar
    1st July 2011
    173
    I always do an oil change when buying a used car for piece of mind if your not sure of the service history then also look at the brake fluid and coolant as a good starting point only other thing to be mindful of is the chains with it being a 59 plate and also the haldex fluids
    11th July 2017
    358
    yip.... unless the owner knows otherwise flush every fluid and consider buying a warranty just incase.
