Results 1 to 9 of 9
    28th June 2013
    96
    Default Astra cd 400 to 600
    Hi I'm after some help I've got a cd 400 i want to change to 600 navi, is there anyone in the oxfordshire area that has a tech 2 that could program it as im told that's the only way it could b done?
    17,899
    Pretty sure the J stopped using tech2 and used the new GDS2 for programming and diagnostics.
    28th June 2013
    96
    Oh really was told anyone with a tech 2 could transfer from 1 car to another
    17,899
    Most likely people who offer tech2 services have now just also added the new diagnostic medium as well.
    17th October 2009
    3,175
    That's right. Tech 2 doesn't work with the J.
    17th October 2009
    3,175
    28th June 2013
    96
    So has anyone got any ideas oxfordshire area that i could get my j stereo changed over from 400 to 600?
    VXRed blooded vocky's Avatar
    5th April 2015
    297
    it's not quite so simple as changing the control box, you need the switch panel, display and trim panel. Then the wiring needs sorting out and a GPS aerial fitting.
    Once thats complete the car will need a VCI check and the 600 will need coding to the car with TECH 3 / GDS2
    Rusty on vxoc is the guy to speak too.
    I changed my CD400+ to a Navi 950, have a read of my thread to see what you might need to do http://www.vxronline.co.uk/forum/sho...47-Astra/page3
    You won't need to do as much going from a cd400 to a Navi 600, but you might have to fit the navi 650 instead (VCI check might not allow a 600)
    16th September 2012
    26
    @Vocky is right.
    In terms of Navi any can be fitted 600/900 650/950 In terms of options DAB DAB+ Bluetooth & Rear camera.
    As Vocky will confirm Rear camera is not a factory fitted option on the GTC/VXR but with some magic Vocky has rear camera.
    There is a draw back and that's that you lose the VXR boot logo.
