Results 1 to 10 of 18
    9th February 2018
    883
    Default Reasons for headlight constantly blowing?
    Hi guys, just wondered if anyone has any input into why my headlight bulb keeps blowing, it's always the same side - the passengers side. I used the same bulbs in each side. In 6 months I've changed passenger side 3 times but in drivers side not once. The bulbs have blown with the standard yellow and the more recent white.
    Anyone any experience with this happening to them?
    18,147
    Maybe a dodgy wire causing a power surge?
    9th February 2018
    883
    I've had bumper off so many times now it's getting annoying but gotta be done I suppose, ok mate how would I know if wire dodgy, just by looking and seeing if it loose?
    18,147
    Yeah give them a good inspection. Maybe source a new loom.
    20th January 2014
    2,163
    How are the bulb connections on that side? Any trace of looseness/corrosion?
    OPC ÉIRE- Drop me a PM for Irish meets, group adds etc.
    18,147
    Can maybe try electrical cleaner on the connections see if that helps.
    9th February 2018
    883
    I'm gonna try and have a look tonight, on some occasions when I thought the bulb had gone it then came back on a day or two later by itself ?? Would this narrow possibilities down? this happened when first got car, now just seems to blow instead of coming back on
    18,147
    That would indicate issues with the connection so I'd say even more reason to clean the connections and see what happens.
    20th January 2014
    2,163
    Not just to clean the connections (if necessary), but make sure the spring mechanism that keeps the bulb firmly in place within the holder is working.
    If the spring metal were flattened, or forming a loose connection, the contact with the bulb may be broken causing the intermittent working you described, or if the contact is close, but not touching, you'll get an arcing condition that's likely to blow bulbs.
    18,147
    Clever these Irish ....
