The connections to the front bumper are a slightly bigger version of those clips which secure the arch liners.
Pretty sure the ones which attach to sub frame are a slightly larger torx bolt. I'll get a look later if I can.
N
Hi all
Need some help with fitting the under tray to the front bumper and sub frame.
Neither of my car have these fitted at the moment.
Need to know :
what kind of fittings are used to secure them (pics if poss)
If I can get fittings from Fleabay
Or part numbers if I have to go to the main stealers
It's the exact same style. That push pin clip, they're just a bit bigger. There's 3 of them. Although I tend to leave them off anyway. Makes all instances where you need to remove the bumper a hell of a lot easier, and the tray still tucks neatly under the lower splitter without the clips.
Looks like there are 3 holes for self tappers in subframe and there are 2 square holes in subframe
I'm not at home at the moment bud so I can't tell you for sure yet.
Leave it off 😂
I lost mine at 130 odd mph at Thunder Road last year. It came lose at the front and scraped along the runway until I'll pulled back in the parking area
Zippi Clips do the Job...........who sees em under there ??????????????
Bookmarks
