Results 1 to 5 of 5
Thread: Scratch 😭
    13th August 2013
    49
    Default Scratch 😭
    Is this scratch fixable without a respray?😭
    18,147
    Simple test to tell. Run your thumb nail over it. If it glides over then it's only in the clear coat and should buff out or at least reduce significantly with a cut and polish. However if your thumb nail catches on it as you move it over its gone below the paint layer.
    VXR enough Jon1796's Avatar
    24th August 2015
    1,634
    Really need you to go over mine, lol😬😬😬
    18,147
    Lol. You'd be surprised what can be wet sanded or compounded out. Clear coat scratches can often look non removable at first glance.
    Even if it's gone below the paint layer a compounding can often take the edge off it so it appears much less prominent.
    VXR enough Markpvxr's Avatar
    10th July 2012
    1,157
    Hopefully come out buddy
    Arden Astra with black bits
    Engine Originally built by wg motorworks blew up after 34 mile so Muni Singh had to sort out his mess 👍🏻
