Results 1 to 2 of 2
    22nd September 2016
    126
    Default Removing steering pump
    Any way to remove and replace power steering pump without dropping the subframe?
    VXR enough COSWORTH's Avatar
    17th July 2013
    1,229
    Not sure if you can, depends if the bolts holding steering rack can be accessed, knowing the way cars are put together these days you will prob have to drop subframe for full access to rack, pipes and steering fluid bottle and the pump.
    Jack it up or get it up on ramps and you will soon find out
