Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
    1st August 2018
    36
    Default Oil change/servicing
    Does anyone have any preferences on make etc looking to change the oil at the weekend oh and also plugs! Not sure on how it was previously treat so going through and servicing things. Any thing else i should look out for/renew.
    Thanks!
    VXR enough Ant21's Avatar
    29th September 2013
    1,507
    Just use genuine parts and you can't go wrong.
    Look out for normal things such as oil leaks, swarf in the old oil & filter.
    I always replace the sump plug on a new car I get, just out of habit.
    Check & replace any fluids you're not sure of, such as coolant, brake, PS & gearbox.
    To be fair, these cars are like any other... look after them and they'll look after you.
    VXRed blooded Andyb712's Avatar
    28th July 2018
    470
    This good stuff mate use it in mine its gm approved and you cant really go wrong with shell
    But the problem is oil is a personal preference but each to their own
    https://www.eurocarparts.com/ecp/p/c...2241&1&cc5_247
    Regional Assistant - Scotland West f1slikki's Avatar
    20th May 2009
    1,495
    Definetely change gearbox oil
    Arden Astra H VXR/Stage 2/6k Afl's/19"Gloss Black Alloys/Powerfold Mirrors/Sight & Light Pack/Parking Sensors/Keyless Entry,Start/Full Remus&Oil Restrictor Bolt By Jigger/Blue,Red SMD By Stampede/Drilled & Grooved Discs/Tints/Green Cotton Filter/Carbon Iinlays/VXR Grill Badge/Private 3D Gel Carbon Plate/Team Hekos/Stubby Bmw Ariel/Debadged//Indicator Surrounds/C,C Bootstrip/Led Side & Plate Lights/VXRO Stickers/
    VXR enough COSWORTH's Avatar
    17th July 2013
    1,229
    I have started using Castrol magnatec from euro car parts
    Compared the price with GM oil from vaux it was no contest.
    VXR enough c19urg's Avatar
    24th April 2011
    2,145
    Oil EVERY 5,000 MLS on mine, I use Petronas.
    1st August 2018
    36
    20th January 2014
    2,163
    Pop the front strut tower caps- may be full with water inside. Dry them out and pack them up with grease.
    VXR enough AndyM's Avatar
    20th April 2006
    1,012
    I always use genuine GM (Vauxhall) parts from either the Trade Club or Autovaux/GPS, good prices. Just did a major services on 2 cars today for less than £150.
    18,147
    As above genuine oil from autovaux is a steal, especially if you have an account there and use them regular.
    No need to break the bank on oil, if it's approved, correct viscosity and does the job you're all good.
