Results 1 to 3 of 3
Thread: Boot flaps
    VXR enough COSWORTH's Avatar
    17th July 2013
    1,195
    Default Boot flaps
    Anyone know the reason for the boot flaps located on the back of the Astra?
    They are located behind the plastic trim that holds the warning triangle.
    They go from boot out the back of car to the rear of the bumper.
    I'm guessing they are stale air vents for the boot, they just feel strange when you work them manually.
    Or maybe Vauxhall were intending using it as an exhaust exit like a Zonda ��
    Actually seen a car I was working on and they used the flaps to run wire for reversing kit.
    VXR enough R34nel's Avatar
    17th May 2009
    2,549
    The what? do you mean boot flaps?
    Stage 3 Arden Astra gone
    Stage 2 burg
    17th July 2013
    1,195
    Yeah that's the ones
