Results 1 to 5 of 5
    8th August 2018
    2
    Default Newbie after some engine advice
    Hi just joined I've had my corsa vxr just over a year now but recently I've found out it's got a cracked cylinder head now do i need a corsa vxr specific head or would one fit off another model tia
    VXRed blooded Andyb712's Avatar
    28th July 2018
    470
    Quote Originally Posted by Tonyp View Post
    Yea mate a cdti head will fit honest
    On a serious note yes you need the head specific to your engine
    8th August 2018
    2
    Cheers for the reply I know a ctdi head won't fit I was told a head off an astra h is the same but looking at it they have got two camshaft sensors is that the only difference
    23rd May 2013
    2,459
    The corsa head has Z18XER stamped on it.
    Z18XER is an Astra 1.8 engine so one of those will technically "fit".
    That said i don't think anyone can confirm if the cams, valves will be 100% the same so there may be a difference in that area and something to worry about depending if you are just swapping the bare astra header or head plus cams etc.
    For easiness sake, and not being a guinee pig you'd probably be best just sourcing a VXR head, e.g;
    https://www.ebay.co.uk/itm/vauxhall-...YAAOSw-95bZWe2
    VXR enough Woody's Avatar
    16th December 2013
    2,020
    Welcome aboard VxRO
    Woody's Vx Ice Addons
