Results 1 to 10 of 35
    26th April 2015
    153
    Question Cruise control😡😡
    Changed brake switch
    Changed clutch switch
    New indicater stalk
    Still wont bloody work!
    Any other ideas?
    Are you VXR enough?
    28th September 2009
    969
    Does it have its own fuse?
    VXR enough Jon1796's Avatar
    24th August 2015
    1,448
    Cim !!!
    24th August 2015
    1,448
    Have you oc to have a look in cim(or bcm I don’t go in every day)you might see on data tables cc see if it acknowledges switching.
    https://www.vectra-c.com/forum/showt...ntrol-problem&
    24th August 2015
    1,448
    Two other thoughts wiring to clutch switch as if brake switch didn’t work no brake lights and contacts in cim corroded.
    Are you VXR enough?
    14th August 2013
    831
    There are so many components that will cause problems with the CC that I don't know if you'll get to the root problem. People have changed about every component part in the chain and have still not solved the problem. I know as I've followed the same process and just gave up in the end. Even now my CC will work one day and not the next. People say to change the CIM, at great cost but people have done and it didn't solve the problem. I haven't seen a post yet that has given a definite solution to the problem. Lots of guides in how to clean the stalk etc but nothing that has been a 100% solution. Not to say there isn't one but I haven't seen anything that has stated otherwise. Even the link in the post above fails to give a resolution
    24th August 2015
    1,448
    Sounds like Vauxhall premium fault.
    1st August 2016
    376
    Detailed answers are on vec c
    Vectra VXR estate 07
    Are you VXR enough?
    14th August 2013
    831
    Where, nothing definitive as I haven't seen a post of someone successfully fix a problematic CC that didn't fail again at a later date?
    24th August 2015
    1,448
    I’ve found some of these problems there is no definitive answer as there all got there own twist on thongs.
