Page 1 of 26 1 2 3 11 ... LastLast
Results 1 to 10 of 255
Thread: My black VXR
    VXRed blooded CoolStory's Avatar
    21st July 2018
    377
    Default My black VXR
    Thought Iíd do a thread. Bought about a month ago. 98k on the clock. More or less full service history.
    Has a full 2.5Ē system. Total decat. Which is putting my engine light on so Iíll be fitting a cat. (I know I can get it mapped out but Iíll still have the issue of getting it motíd and I cba to keep having to swap a system over each year plus there wonít be any benefit imo to having a cat fitted on a standard car-not noticeable anyway)
    Iíve fitted a recirc valve to cure the turkey sound and modded a cdti airbox myself and fitted it.
    Has a slight oil leak from the rocker which needs sorting. And yesterday I tried changing the droplinks but theyíre well stuck. Couldnít get them off so looks like Iíll be cutting them off!
    Any way some pics
    https://i.imgur.com/FpzLg3l.jpg
    https://i.imgur.com/WI5k9dY.jpg
    https://i.imgur.com/ZS0dqwZ.jpg
    VXRed Jmoore11's Avatar
    16th July 2018
    15
    Looks nice mate yeah i need to change my rocker gasket as well dripping into the spark plug bores causing issues haha
    21st July 2018
    377
    Quote Originally Posted by Jmoore11 View Post
    Cheers pal. Yeah mines leaked all down the block. Looks rancid. Once Iíve changed the gasket Iíll clean it up
    VXR enough Cnking's Avatar
    3rd August 2011
    1,307
    Looks real nice in black and I think everyone has done that I did it in my first one and my current one easy enough job
    Sent from my ONEPLUS A6003 using Tapatalk
    16th July 2018
    15
    what re circ did you go for?
    17,286
    Just torque the rocker bolts correctly after gasket replacement to stop it happening again.
    21st July 2018
    377
    Cheap eBay one for now. Just to get me by. Was sick of the noise
    Good shout. Iíd imagine people do it too tight and it squashes the gasket
    3rd August 2011
    1,307
    If you look ok on my build thread there is a picture on there showing you exactly how to do it "kings build thread"
    17,286
    Can ruin the threads too. Torque to 8nm max in the correct order.
    21st July 2018
    377
    Quote Originally Posted by Cnking View Post
    Cheers will take a look.
    Would you guys recommend buying genuine or will eBay one do?
    Iíll get some stainless steel bolts too
