Results 1 to 5 of 5
Thread: Alloys
    13th July 2016
    25
    Default Alloys
    Hi there, Iam looking at changing the alloys on my zafira, at the mo it’s got 18” alloys on it, I’ve just had it lowered by 40mm lowering springs on ids struts dose anyone no if a set of 20” alloys will fit the zafira vxr. Thanks
    15th May 2013
    17,939
    Personally I would stick on 18s especially on the basis your now lowered too.
    You will get 20s on at a push with a very low profile tyre on but it will ride awfully
    13th July 2016
    25
    Il leave the 20” alloys idea, I’ve seen some 19” Vauxhall vxr alloys with 225 35 19 for sale do you no if the ride will be bad as only dropping 5mm if tyre, even though I’ve lowered the car there is still a gap in wheel arch’s to fill. Thanks
    VXR enough britishbeef's Avatar
    11th October 2006
    3,190
    19" look better 18" drive better
    Are you VXR enough? Andyb712's Avatar
    28th July 2018
    767
    Personal opinion I prefer the19's I reckon they hold the road better granted a rougher ride but definitely handle better
