Results 1 to 10 of 18
Thread: No power
    31st August 2018
    11
    Default No power
    Hi i have a problem with my vectra vxr,on starting in the morning it runs lumpy then the engine note changes, the engine management light flashes 11 times then stays off but the car will not run properly no accelaration,feels like its only running on 3 cylinders? Any ideas on what could be wrong? It will then run ok if i stop the engine and leave it for 5 mins but the tickover is still lumpy
    VXR enough V6spike's Avatar
    18th May 2013
    1,847
    Get it code read but likely coils,plugs or both
    1st August 2016
    444
    Its ******
    Vectra VXR estate 07
    Are you VXR enough?
    28th September 2009
    989
    People have said a cylinder with a misfire flashes to identify it but I don't know if an entire bank misfiring would just add up to all 3 cyclinders since it would be 1-3-5 or 2-4-6 if it's in the same bank. Could make sense if you are saying it's on 3 cylinders.
    Someone may say chains if it's misfiring an entire bank but I've no experience to comment on that.
    It happened to mine once where the car **** itself and only 3 cylinders were firing but that was bad fuel (the wife filled it, probably with water)
    Are you VXR enough?
    28th September 2009
    989
    And check for air leaks, though not sure if that would make the EML flash multiple times
    VXR enough Jon1796's Avatar
    24th August 2015
    1,675
    Yep get codes to see what’s up then go from there.
    Are you VXR enough? andy-'s Avatar
    12th May 2010
    931
    get the codes read first as that will begin to narrow down where the issues lie
    Vectra VXR 280 . Courts Rad and Intercooler. Miltek cat back. K&N Panel. Eibach's. TD 1.2s
    31st August 2018
    11
    Update,bought a scanner with live data it has come up with fuel system open loop fault also when the problem happens there's misfire codes on cylinders 1-3-5 which is the rear bank if i then switch off engine and turn ignition on and off several times the problem goes and it runs normaly?
    24th August 2015
    1,675
    Do you know if it’s mapped???
    Are you VXR enough?
    28th September 2009
    989
    Can you check fuel trims? Could be an air leak potentially or maybe the o2 sensor has a fault if you can get readings from that etc.
