Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: No power
  1. #11
    VXR enough Jon1796's Avatar
    24th August 2015
    1,675
    Quote Originally Posted by mikez1 View Post
    Can you check fuel trims? Could be an air leak potentially or maybe the o2 sensor has a fault if you can get readings from that etc.
    I’m thinking more ecu as it disappears after restarting. Poss need remapping.
  2. #12
    24th August 2015
    1,675
    As injectors run by ecu and if fault on rail all would be throwing up fault.
  3. #13
    24th August 2015
    1,675
    Or chains ???
  4. #14
    11th July 2014
    366
    Have you just bought the car? I know someone got rid of theirs due to a bad remap, it never ran right after and was "locked" apparently.
  5. #15
    1st August 2016
    444
    Bloody hell, why didn’t they just get it remapped?
    Vectra VXR estate 07
  6. #16
    z28 open block surgeon nick150's Avatar
    1st April 2012
    3,497
    What I would do is check all pipe work is secured
    More so on the secondary air circulation
    Then switch all plugs and coil packs from front to rear if symptoms persist and codes remain the same I'd say your looking at something more serious
    NOW STAGE 3 BUILT BUY ME POWERED BY SUPERCHIPS.
    INSIGNIA TURBO,INSIGNIA INJECTORS,QUAFE DIF,PADAL CLUTCH,COURTNEY RAD AND INTERCOOLER,3 INCH SYSTEM,BILSTEN B12'S,AP RACING BRAKES,POWERFLEX BUSHES
  7. #17
    31st August 2018
    11
    Had to put car in garage they cant find anything wrong but will only run on 3 cylinders ,i have changed both oxygen sensors.fault codes say misfires on multable cylinders,all timing chains were changed about 3000 miles ago.
  8. #18
    31st August 2018
    11
    had ECU tested and all is ok new code has shown up,fuel rail sensor input high?
