Results 1 to 9 of 9
Thread: Ids+
    VXRed Robs-se's Avatar
    28th December 2012
    245
    Default Ids+
    Need to change the front struts, are they plug and play or do they need deleting and paired?
    Are you VXR enough?
    28th September 2009
    964
    Plug and play, at least mine were...
    VXR enough Jon1796's Avatar
    24th August 2015
    1,338
    If you’re changing oem for same no problem.
    If you change to other you’ll need to remove ids from system or you’ll have dash lights on.
    28th December 2012
    245
    Replacing old for new.
    24th August 2015
    1,338
    Front dampers
    https://r.tapatalk.com/shareLink?sha...3&share_type=t
    They just take awhile. But cheaper and just refit.
    24th August 2015
    1,338
    Ahh you posted it.......lol
    28th December 2012
    245
    Lol, just waiting on Autovaux to deliver the full set of springs now.
    24th August 2015
    1,338
    When you do fit them put axle stand under lower arm, lower on to it to put pressure on it then tighten up.
    Are you VXR enough? andy-'s Avatar
    12th May 2010
    881
    Plug and play. I did my fronts earlier in the summer
    Vectra VXR 280. Milltek cat back. Courts upgraded radiator. Courts intercooler. K&N filter. Eibach springs. TD Pro race 1.2s
