Results 1 to 10 of 12
    16th April 2014
    25
    Default warning hazard Car Skidding
    Question :- The hazard warning light has come on - which to me means it prevents skidding? Why would this come on though?
    How does one solve it / remove it?
    18,543
    Do you mean the esp light? Pic of the car with skid marks?
    If that's on permanently is normally a sign of the maf sensor failing.
    16th April 2014
    25
    Thats the 1. So where is the maf sensor hidden? what do you have to do to replace it?
    18,543
    It's attached to your pipework just off your airbox. Simply unplug connector and remove from the pipework and replace.
    Do you have any running issues? Misfires? Car cutting out?
    16th April 2014
    25
    No the car is running good. The only thing I notice is there is a click when I break, but other wise drives like a dream
    18,543
    Are there any fault codes if you do the pedal test?
    Are you VXR enough? Andyb712's Avatar
    28th July 2018
    767
    Is the abs light on too?
    16th April 2014
    25
    Hi I have no other fault codes and the brakes work well. The abs light is not on either. I have tried what the book says and that is to put the sport
    button on and turn the engine off and then back on. But the esp light stays on. Found the sensor or sensors as there are 3 on the pipe. Just got to work
    out which 1 it is. By the way my vxr is 56 reg if that helps.
    19th January 2014
    2,170
    Quote Originally Posted by marlie View Post
    Hi, I have no other fault codes and the brakes work well.
    The abs light is not on either. I have tried what the book says and that is to put the sport button on and turn the engine off and then back on.
    Just got to work out which 1 it is.
    Put up a post asking if anyone in your area has Tech2 to plug in.
    Even a faulty ABS valve modulator can cause the ESP to illuminate without showing up ABS fault or any pedal test codes.
    OPC ÉIRE- Drop me a PM for Irish meets, group adds etc.
    16th April 2014
    25
    I took the car to my local garage who did the health check on the machine and it identified that the ESP pump is faulty and the sensor is inside the control box
    so I need to send my esp pump away to be reconditioned . Also, I was informed that my power steering will not work until this is done.
    Any idea of any good companies that can do this and do it in a positive quick return ?
    I do not want my car odd the road long term as I need it for my work
