Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
    VXRed Dean@vxr's Avatar
    24th August 2018
    20
    Default Fitting a Remus Astra h
    Allrite guys
    Iv got a full Remus system which I bought but not had time to fit I’m looking at getting it on my vxr do I need to replace the v band clamp from turbo or is this reusable
    26th February 2012
    1,772
    reuse it as long as it doesn`t snap
    24th August 2018
    20
    Yes pal I’m going to be gentle with her I just priced it up at my local Vauxhall dealer and they £80.80 which I think is a little rich! Would you recommend heating up slightly I’m going to get on it tomorrow see how it goes
    VXR enough Ant21's Avatar
    29th September 2013
    1,505
    I've had my V-band off a few times now. I always find the best way to get it off if it's stuck is to loosen it, then give it a gentle tap with a long screwdriver and a hammer. It will soon come off.
    No need for heat / lubricant.
    17,913
    As long as it's not warped you can reuse.
    24th August 2018
    20
    No mate it’s not been wrapped I’m going to have a go tomorrow anything else I need to know the rest looks straight forward to assemble
    24th August 2018
    20
    17,913
    Sometimes you can't tell until you have the clamp off and can see the lips which lock the 2 pieces together.
    Other things to look out for I'd say the tightness of the lambda sensors in the old exhaust. Can sometimes be a pain.
    24th August 2018
    20
    Cheers for the knowledge il attack it tomorrow il be ok with the sensors the Remus as both still attached so planning on just using those
    17,913
    Quote Originally Posted by Dean@vxr View Post
    Ah that's a bonus. It's quite a ballache getting to the bank 2 connector though.
