Cool, if its the original 200 cell cat then they need a good long run every now and again to keep them efficient. Also for passing the emissions test they need to be really hot!
Pedal test should come up the the lambda error I'm sure.
Yes it’s got the sports car fitted mate I haven’t done pedal test I just been reading about that tbh
Just done the pedal test it’s came up with 042011 any ideas pal
I'm sure that's for the bank 2 sensor - so the one in the cat; 'catalyst efficiency below threshold'
I assume you bought the exhaust second hand? try take it on a long run and if that doesn't help use some cataclean. failing that it might need replaced.
Sound then mate yes was second hand system well il start with the cheap option and work my way through cheers for your help
no probs - I don't think the light will go out by itself, but after you have tried the above options reset it each time and see if it comes back. Using V Power or Momentum 99 also helps keep it clean. The previous owner could have run it on normal unleaded all it's days... you never know. ha.
Not the cheap mans fuel lol il try sort out if no joy il get decat and mapped out that will do the job
yeah, then just find a friendly MOT tester. haha.
Bookmarks
