Results 1 to 10 of 13
    9th September 2018
    6
    Unhappy ESP Warning Light
    Hi,
    I was driving yesterday and the Service ESP light came on my dash. It felt very shakey, and was not running on full power. So I checked all my gauge pressures on my screen, and the boost pressure wasnít registering, but then it went off, but then has come back on. Can anyone give any advice please? (Please donít tell me itís the turbo, and just a dodgey sensor or something)
    Also, I am currently 340miles from home so I am limited to what I can do and where I can go!!
    Thanks for any help and advice!
    3rd September 2015
    417
    Is it still here after restart ?
    Could be a small overboost then it is in limp mode until fault code are cleared...
    or something else...
    We can only tell with DTC codes
    9th September 2018
    6
    It was on this morning when I first started it up, but went off after a minute and hasn’t, been back on. The boost gauge is back on, but I can still feel it lagging a little bit, but just taking it steady, so touch wood it hasn’t been back on!
    Thanks!!
    9th August 2011
    2,543
    could it not be a faulty ABS sensor , these are more often than not hooked into the traction control systems so can cause issues if failing
    9th September 2018
    6
    Cheers guys! Hopefully will hold out till I am back home and get my garage to have a look!
    9th August 2011
    2,543
    a code read would be very handy pal
    17th September 2011
    959
    Did you do some “spirited” driving when it happened? The brembos are not the worlds best brakes for heavy use (which seems odd on a 2t, 325 bhp car). I had the exact same symptoms after af good thrashing. I braked from 200 kph to around 60 kph and the car had significant lag and heavy shaking and the ESP lamp came up. Limped home, limped to the local Opel garage next morning (2 km) but before I reached the workshop, the light had gone out and the code disappeared and no shaking. The mechanics came to the conclussion that one of the pads had seized up due to the heavy braking.
    The slight lag you feel could either be the pad still sticking a bit, or just the psychological effect messing with you
    Anyway, I only experienced it once and the car never complained again.
    9th September 2018
    6
    I wasn’t hammering it, but I had to brake hard, so might have been that! It hasn’t been on again today, so touch wood it was just that! Thanks again!! The beast lives on
    9th August 2011
    2,543
    I reckon the problem with these Brembo's is the pad material is too thin and cant dissipate the heat generated and obvs if your pads are say , half worn , the problem is even worse , they overheat and rattle against the disc till they cool sufficiently , I guess the cure is higher temp pads but they tend to be crap from cold
    VXR enough AJG's Avatar
    10th January 2010
    1,321
    The brembos are not the worlds best brakes for heavy use (which seems odd on a 2t, 325 bhp car). I had the exact same symptoms after a good thrashing. I braked from 200 kph to around 60 kph and the car had significant lag and heavy shaking and the ESP lamp came up.
    Yep, the Brembos do that after a good thrashing; in my case the Nordschleife. The vent holes become blocked with brake dust causing overheating and the callipers to lock. First reported on here way back in 2010 by one of the first owners http://www.vxronline.co.uk/forum/sho...tilated-brakes. Been a recognised problem ever since.
