Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
  1. #11
    13th May 2008
    21,632
    Forgot to mention --- major wear on fronts are always on the inside edges - check with full strip down or an initial feel with the fingers ......
  2. #12
    VXRed blooded CoolStory's Avatar
    21st July 2018
    458
    Quote Originally Posted by R15VXR View Post
    .........- check with full strip down or an initial feel with the fingers ......
    Are we still talking about brakes?
    Thanks mate. I will give it all a good going over. Thanks for the info
  3. #13
    17,913
    I have a brand new set of gm oe pads in the garage ready to swap for my textar oem replacements. I often get tempted to swap them now but there still a good half the pad left on them textar so would be quite a waste.
  4. #14
    VXRacing ahead tye_time's Avatar
    24th February 2017
    614
    I've always wanted to try ceramic pads for dust reasons... Need warmed up for decent braking performance though don't they?
    - sent from OP5T
  5. #15
    17,913
    Expensive regardless .....
  6. #16
    13th May 2008
    21,632
    Quote Originally Posted by tye_time View Post
    - sent from OP5T
    I priced some up last time and decided not to go down that route.
    The ceramic pads I looked at needed Ceramic discs to work with
    Could of been good ......but there again you would need to look at that cost against the cost of going down either the big brakes route or even the veccy conversion route
  7. #17
    20th January 2014
    2,153
    - sent from OP5T
    Look into the TRW DTEC range.
    OPC …IRE- Drop me a PM for Irish meets, group adds etc.
  8. #18
    21st July 2018
    458
    Default Brakes on my vxr are worse than my cdti!
    Vectra vxr brakes would be a good upgrade. Donít they have vented rears too?
  9. #19
    24th February 2017
    614
    Quote Originally Posted by VeXeR View Post
    Will do
    - sent from OP5T
  10. #20
    13th May 2008
    21,632
    Quote Originally Posted by CoolStory View Post
    AFAIR, you only replace the fronts or most did back in the day with the custom made brackets. The main issue with improving the rears would be stability of the car iirc
