Results 1 to 6 of 6
    VXR enough chodiddly's Avatar
    12th December 2015
    1,647
    Default airtec information please
    Hi Guys,
    Just a bit of info needed really.
    I was thinking of ordering an airtec front mount intercooler the stage 2 one.
    Do i need to order any hoses WITH the intercooler for it to fit or can it go to standard pipes as i havent changed any boost hoses or anything?
    Thank You
    15th May 2013
    17,916
    It will come with all the necessary pipes needed up to the map pipe.
    Enhance performance sell a kit that includes a new map pipe, hose and top hat I believe that if you wanted that too
    12th December 2015
    1,647
    so map pipe is the middle pipe.....top hat is the bit on top of the map pipe and the hose is the bit connecting into the map pipe?
    so airtec would go straight into the current unmodified hose?
    sorry to sound dumb just want to be 100% clear before ordering
    17,913
    It should fit into the oe hose. As I'm pretty much 100% sure it comes with a reducer hose to the map pipe. However, to get the full benefit airtec also do a tophat and power pipe kit which will replace the oe versions and help maximise flow.
    12th December 2015
    1,647
    ah right ok thank you mate
    whats better the alloy pipes or the silicone? i dont really like the alloy stuff but was told alloy is better than the silicone stuff?
    17,913
    I like the alloy hard pipes. Theoretically they should produce better flow as the pipe walls can't stretch under pressure like a silicone can but in all honesty it won't make a noticeable difference. So go with what looks best to you.
