Results 1 to 10 of 13
    VXRed som72som's Avatar
    17th March 2018
    15
    Default Stage 2/Pops & Bangs
    Need some advise here.
    So back in August I had an induction kit, Scorpion secondary de-cat & a Scorpion non res cat back fitted. Had it remapped to a stage 1 which went very well with no problems.
    Today I had a Scorpion primary de-cat fitted & had it remapped to a stage 2 was hoping to increase the power as well as get some pops & bangs from the exhaust.
    No pops & bangs but the power increased slightly but at top end. But from 40mph if I give it some the clutch slips.
    From what Iíve been told this is normal so I would need to invest in an upgraded clutch & that Astra J VXRís canít get pops & bangs mapped in.
    I have attached dyno graph results below.
    Any help & advise will be appreciated.
    18,204
    Direct injection = much more efficient burning of fuel so none spare to ignite and bang.
    You need an H to get them.
    17th March 2018
    15
    Cheers mate, any ideas on the clutch slipping?
    18,204
    I'm not the best to advise you on that mate. I'm an H owner and only really extensively know about that lol.
    I just know that the J used direct injection like the vag cars, so pops and bangs aren't as forthcoming as from the older H.
    17th March 2018
    15
    Ok cheers fella
    3rd May 2017
    168
    Just had my J done at WG Motorworks to Stage 2 and I was told that the clutch can slip, apparently it's hit and miss. Last year I had a new clutch and flywheel and luckily my clutch does not slip at Stage 2.
    I do not get pops and bangs.
    My Stage 2 included a primary de-cat (secondary left in), induction kit and uprated spark plugs. One thing I've noticed on your graph is your torque is quite low for a Stage 2 and I am surprised your clutch is slipping at 347lbft but I suppose if it's worn it will slip. Mine is making 390lbft and 320bhp and it's fine. Quite an odd torque curve as well but I suppose each tuner does it different.
    I recommend you either replace the stock clutch or take the opportunity to go for an uprated clutch... See here for more details:
    http://shop.wgmotorworks.co.uk/index...&search=clutch
    You retain the stock DMF with the uprated clutch.
    3rd May 2017
    168
    Hereís my graph
    17th March 2018
    15
    Quote Originally Posted by V*X*R View Post
    Hereís my graph
    Thanks for your response, I think I will contact WG & pop to see them. Would you have their contact details mate?
    3rd May 2017
    168
    Best thing to do is send an email to info@wgmotorworks.co.uk. He’ll normally reply the following morning. If they aren’t local then use Courtenay Sport instead as they are also highly rated for tuning / mapping
    17th March 2018
    15
    Best thing to do is send an email to info@wgmotorworks.co.uk. Heíll normally reply the following morning. If they arenít local then use Courtenay Sport instead as they are also highly rated for tuning / mapping
    Thanks mate
