Results 1 to 10 of 34
    18,204
    Default Accessing secret menu on CID cd70?
    How do you access the hidden menu that shows engine temp etc on the CID and cd70? Can't remember the process for even the other head units.
    20th March 2016
    371
    IIRC hold the settings button for 10 secs, should bleep then just scroll through.
    18,204
    Ah that sounds familiar. I'll give it a shot on the morra. Ta.
    VXR enough Ant21's Avatar
    29th September 2013
    1,508
    Yep as above. Use BC to scroll, or navi, radio etc to see all their sub menus.
    18,204
    18,204
    Just to confirm, does the engine have to be on? Tried with it off and nothing more came up.
    29th September 2013
    1,508
    Nope, however to get accurate readings you'll need at least the ignition on, but ideally the engine running to see accurate coolant temp so you're not looking at any heat soak etc...
    You should just be able to hold the settings button on say your home radio screen for example for a few seconds until it bongs.
    It will also say on the CID with a little pop up 'testmode switched on'
    Once you get the above, simply scroll away.
    18,204
    Did all this with the ignition on but no engine. It bonged. Then nothing else. Menu was the same.
    29th September 2013
    1,508
    Did it say test mode switched on?
    If it bonged, you’d assume it’s been activated and so can scroll through.
    VXR enough R34nel's Avatar
    17th May 2009
    2,550
    I pretty much do this daily on the cd70, hold settings for 5 secs til it bongs, then press bc 5 times to reach the screen with the water temp on, if you are not on the radio or mpg tab on the main screen then you will end up in nav test mode, if you are in any of the other menus or screens it doesn’t work
    Stage 3 Arden Astra gone
    Stage 2 burg
