Results 1 to 10 of 10
    7th March 2017
    20
    Default Rough Idle & 'bumpy' start - Confused beyong belief lol
    Howdy folks, as my beloved has been 'running', OK'ish, I've somewhat, put this off - bad idea & move I know...
    The Story: recently, my idle has become very rough even after tick over (up and down) and when I set off in low revs, there's a real bad shudder (in a few gears - however, when I give it a bit of the old gas it's fine)? Hmm..
    I thought it was the MAF playing silly buggars so I replaced it, no difference.
    Strange thing is, when the MAF sensor is unplugged, there's no increase or change to idle/revs as you'd expect - which leads me to believe it's a wee bit more serious than the MAF? I've done a pedal test and no error codes (bar temp sensor - it fell off lol).
    Any ideas as to what to check, or is this going to be a can of worms when looking in to it? As Peter Griffin once said, it's 'grinding my gears'.
    Any help, knowledge of the issue or anything - even things to check, I would be super greatful!! Thanks for reading kids!
    Birmo
    VXRacing ahead Rksmith's Avatar
    15th December 2016
    515
    The usual mate
    Coil pack (Bosch if replacing)
    Spark plugs (platinum ones ngk)
    02 lam sensor on precat (again Bosch if replacing)
    Coolant temperature sensor.
    Go from there I would bud.
    10th June 2015
    143
    Get rid of it mate it sounds ******.
    7th March 2017
    20
    cheers mate!
    VXRacing ahead Andyb712's Avatar
    28th July 2018
    566
    Got similar problem mate but mine is the rev counter fluctuates when held at constant revs say 1500 rpm and it flickers up and down a bit
    One thing I did see on another thread was inlet manifold gasket being the culprit
    7th March 2017
    20
    Well, I honestly can't believe it - I'm not very technical but... took the coil pack off, looked down 2/4 we're black - seemed 2 plugs decided to try and escape. I guess I was running on 2 cylnders haha
    Replaced all 4 spark, and hey presto!
    Idle restored to normal, no stuttering and back to full power! Time for another service.
    15th December 2016
    515
    Quote Originally Posted by rob.birmingham View Post
    Good to hear mate
    18,204
    Quote Originally Posted by d fry View Post
    Such a spirited warrior displaying such desire to try and tackle the problem
    18,204
    Yeah you'll find 90% of running get issues come down to the basics. Especially seen as the engine running is automatically controlled. Just provide it with working sensors and ancillaries and it'll work fine.
    7th March 2017
    20
    I'm just glad it wasn't anything major, got my MOT and service next month!
    Thanks all! #Happy Black VXR dude lol
