Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 58
    17,899
    Default Astra vxr .... jacks are apparently no no .....
    According to the manual .....
    Jacked mine up untold times. Using the required jacking points of course .....
    VXRed blooded bottlebill's Avatar
    11th September 2015
    252
    When I had my 'H' I found that the VX jack wouldn't fit onto its location (at the back) because, if I remember correctly, the body kit was fouling the jack. I bought a Halfords jack and managed to jack it from one of the arms. I have a 'J' now and it doesnt come with a jack. I bought one but again will jack it up from one of the arms.
    My 'H' was fitted with 19 inch rims and the original owner bought a fifth wheel as a spare - great.
    VX penny pinched on the 'J' - no spare, no jack, and you blow the tyre up with a repair foam and the garage wont fix it !!
    VXRed blooded CoolStory's Avatar
    21st July 2018
    458
    Pisses me off cars come without a spare wheel nowadays. Space savers were bad enough but half of them don’t even get that.
    I believe the H VXR doesn’t come with spare either and just the repair pump up ********
    17,899
    The vxr wheels are too big and expensive for a spare to be financially viable.
    And a spacesaver would be too small to mingle with the other 3 big wheels.
    23rd May 2013
    2,427
    Does the Astra have the spare wheel well?
    Corsa SRI Turbo (SOLD) and Facelift Corsa 1.4 SE (SOLD) - Now Ecoboost Fiesta 140, Suzuki GS500 and Kawasaki GPZ900
    21st July 2018
    458
    Yes
    9th February 2018
    780
    I've had many flats recently as I work in a screw factory, and I too was ****** off with no spare on my corsa. I bought brand new tyres and got a screw in the centre of one, I knew it was repairable but also knew if I used the foam it wouldnt be repairable. So I basically had to take wheel off leave over night and bring back next day fixed . My corsa also had no jack?? But not sure if that's because past owners lost. I do like the built in compressor though, that comes in handy
    17,899
    I actually bought a Halfords air compressor. .... totally forgetting the cars inflation kit had one .....
    And like the astra mate as the vxr corsa has extended skirts etc there was probably no jack included as it was viewed as "unsuitable".
    Your manual should tell you.
    9th February 2018
    780
    Didn't get a manual mate, hell I didn't even get the lock in wheel nut to take wheels off!! Ive since download manual though and bought a low profile jack. The compressor good for bike wheels etc on trips why they put space for spare wheel in astra if they didn't add one? In case the owner wants to buy one afterwards? I think a jack added should be compulsory just incase you do decide to buy wheel. Plus I dont know how good the foam is as never used, I'm assuming if tyre ruined then this wouldn't help thus needing a jack to remove wheel
    17,899
    The base chassis are all the same mate. the wheel well would obviously have housed the space saver on the smaller wheel models.
