Page 6 of 6 FirstFirst ... 4 5 6
Results 51 to 58 of 58
  1. #51
    VXRed blooded CoolStory's Avatar
    21st July 2018
    458
    First aid kit is supposed to fit under the elastic strapping on the right hand side of the boot. Warning triangle slots into the recess in the boot just inside the boot door
    Awesome! Always wondered what went in those! Will be buying those!! Thanks mate
  2. #52
    21st July 2018
    458
    Just told my mrs “SAD”
    Did all H’s come with these from factory or?
  3. #53
    18,193
    I'd imagine at one point yes. But ill bet it was included in a bonus "pack" which was another optional extra. But if you read the manual it mentions the warning triangle and first aid kit as if they're meant to be there.
  4. #54
    VXRacing ahead Andyb712's Avatar
    28th July 2018
    563
    I'll take being stranded thanks after what those t**ts did to me .....
    Try startrescue adam dam cheap and never had a problem with them
  5. #55
    The Red Baron... Deathace's Avatar
    25th May 2011
    6,964
    I had the original triangle as part of my space saver purchase and it did not fit in the recess in the boot as expected, the plastic box was too long no matter how I collapsed the triangle so I sold it to someone who wanted it and bought an AA kit in a bag with first aid kit which goes in the car when I travel to Europe and goes back in the cupboard when I return I use the straps for the first aid kit in the boot for a fire extinquisher as that may come in handy
    Russ
  6. #56
    18,193
    Quote Originally Posted by Deathace View Post
    Russ
    You have to make sure it is packed properly in the triangle case. If it's right in there you have to slot the left side in first then it should sit nicely into the recess
  7. #57
    7th January 2019
    10
    HI guys, I have a 2015 Astra VXR. I have 20" wheels on it. I'm looking to get hold of a space saver spare wheel, Any ideas what's available?
    I got hold of a Zafira wheel as it has 5 holes but, it doesn't fit, the VXR studs are wider...
    Any help and advice would be appreciated. Thanks in advance
  8. #58
    18,193
    Pretty sure on 20" wheels a space saver would be a no go as the diameter is tiny.
