Results 1 to 4 of 4
Thread: P0136-48
    VXRed Muncie's Avatar
    15th September 2014
    71
    Default P0136-48
    Can anyone tell me if this is the result of gutting my pre cat? I had put in a 90° spacer but I have a feeling this hasent stopped this code. The reason I ask is my car was off the road for the last 12 month and while it was in the garage for all that time I did a few mods One of them being the decat.
    VXR enough V6spike's Avatar
    18th May 2013
    1,849
    Bank 1 did you put the spacer? It’ll need mapping out or clearing the DTC. However I think a spacer isn’t required??? If so I’m sure I’ve read on bank 2
    15th September 2014
    71
    Iv put a 90° spacer in the second 02 sensor bank 2. I tried to clear the code with vaux com but it's pending so it never clears. I will get it mapped out if the decat is the issue I just don't want to go book it in and get turned away becuse of other issues.
    VXR enough Jon1796's Avatar
    24th August 2015
    1,711
    You might have to do some checking, wiring, disconnect sensor, see if it can tell if it’s missing or replace it. Plus check for any leaks from inlet to manifold past sensor.
    The 90% might also have taken it out to far, isn’t more common to put the straight spacers on ???
    You could also do a live data run and record it and go though data to see if it’s anything else.
    http://www.carnewscafe.com/2014/10/p...-engine-codes/
    https://www.engine-light-help.com/ox...sor-codes.html
