Results 1 to 10 of 11
    VXRed XenonVXR's Avatar
    26th July 2017
    246
    Default Not the oil question you’d expect
    Right so first off I know I’m a muppet for doing this but I topped my oil up and put the can in the boot, evidently I didn’t close the lid on it well enough and now the boot panel is soaked in oil pretty much, anything I put in there gets greasy and oily, what’s the best remedy to get this oil out the boot carpet or am I going to need a new one? It doesn’t smell of anything just greasy to touch🤦🏼*♂️ thanks in advance!
    18,451
    Try a highish concentration of all purpose cleaner. Try giving it several sprays and use an upholstery brush. Then blot it with a decent microfiber to dry it.
    Apc is a degreaser so in a high enough concentration it should break the oil down.
    Failing that a solvent like tar remover will work, but that's a bit more aggressive than I'd suggest going on the carpet fibres.
    Had a similar lapse last week when I Brought my new oil home to change. Leaked from the top and id put it down on its side in the passenger footwell. Luckily I have rubber floor mats so it was a breeze.
    VXRed blooded CoolStory's Avatar
    21st July 2018
    458
    Would washing up liquid also work?
    18,451
    Quote Originally Posted by CoolStory View Post
    Yeah it won't be as potent as a proper apc at high concentration but if it's all you have.
    26th July 2017
    246
    Okay perfect, thanks guys!
    Any particular brand you guys would suggest?
    18,451
    There's lots of top brands.
    Meguiars detailer all purpose cleaner and bilt hamber surfex hd are my favourites.
    2nd September 2018
    2
    I had this issue with a previous car I had bought opened up the boot took all the doormats out that someone had put in there to find my boot carpet was oily and greasy I tried everything from brake cleaner to fairy liquid and nothing got it out properly even the jet wash wouldn’t budge it even though I didn’t exactly expect it to but in the end I had to get rid of it and replace with new nothing I used for it out brake cleaner worked the best out of them all but it gives you a headache after a while from the smell and it only takes the top layer off and still leaves it soaked and penetrated into the actual fibres
    6th May 2017
    822
    Could try a degreasing hand cleaner or fluid and scrub gently with a soft brush before rinsing thoroughly. I would test a small area first to ensure it doesn't react with anything or leave a strong smell.
    Are you VXR enough? Euro's Avatar
    7th November 2011
    755
    In reality replace it. Even a carpet cut off made to fit would be better. Otherwise it will linger and you'll never be satisfied
    19th January 2014
    2,169
    If you can remove the fabric panel and if washing up liquid alone doesn't work, submerge it in water and weight it down- the lesser density of the oil means it should try to float up (slowly). Add washing powder. See how she goes.
