Results 1 to 8 of 8
    VXRed XenonVXR's Avatar
    26th July 2017
    246
    Default Drivers side seatbelt
    Hi guys
    So since Iíve had the car my drivers side seatbelt doesnít seem to want to retract, or if it does itís stupidly slow the amount of times Iíve trapped it in the door is unreal, Iíve tried spraying polish on it but it lasted the whole of an hour, what do you guys suggest?
    VXRed blooded CoolStory's Avatar
    21st July 2018
    458
    Pull the belt all the way out and spray furniture polish on it both sides. Work it in and out a few times and it should improve it.
    20th June 2018
    20
    exactly what CoolStory has said I had to do mine a few times but it gets better and better every time you do it
    26th July 2017
    246
    Okay Iíll have to give it another go then, tired it before and like I say worked for about an hour wasnít sure if the mechanism had a fault of not, thanks guys!
    21st July 2018
    458
    Youíll more than likely find itís lint stuck on one of the rollers. Ideally youíd be better taking it apart and cleaning it all. Of course the mechanism could be just worn out. Rare though
    VXRed Noxious89123's Avatar
    22nd June 2014
    174
    Furniture polish? Not sure I'd want that all over my clothes tbh.
    I had the exact same problem, with my drivers side belt, I did a bit of digging and went with one of the 2 methods recommended on detailing world.
    Put a bit of persil in a bucket, fill with hot water.
    Unspool the entire belt, and use a bulldog clip or clothes pegs near the top to stop it retracting.
    With the door open and the bucket next to the sill, put the belt into the soapy water. Works best if you agitate it a bit rather than just leaving it to soak. My belt was pretty minging, so I used a soft nail brush on the belt as well, but you want to do this really gently; you don't want the belt to start fraying or otherwise damage it.
    Chuck the water away and refill the bucket with hot water (no soap). Rinse the soap off the belt. (I did this more than once).
    Leave the belt to dry naturally.
    I did this during the last heatwave, and just left the windows on the car cracked open. Was dry in about an hour, and the belt retracts like it should now!
    The other suggested cleaning method on detailing world was to use an APC suitably diluted, sprayed onto the belt and wiped off with a microfibre. The soiling on my belt was quite bad, plus I didn't have any APC, so persil won out for me!
    As always, test cleaning solutions on a small inconspicuous area first, to make sure it doesn't affect the colour. I have blue belts in my GSi, and suffered no loss of colour. (Other than removal of the brown filth that was on the belt!).
    It was actually someone at work that suggested I could fix the belt simply by cleaning it; I didn't expect it would work as the belt really didn't have much "pull" at all, but cleaning it worked great!
    Astra GSi ~ VXR Injectors / VXR 80mm AFM / VXR Turbo / CDTi Airbox / TS Recirc / K&N / 3" Piper Exhaust / CS FMIC / EBC YellowStuff / Bridgestone S001 / Bilstein B12 Pro-kit / Whiteline RARB
    CS Mapped 285 BHP / 340 Ft.lbs
    21st July 2018
    458
    To be fair you donít get furniture polish on your clothes unless youíre a big fat ******* because you pull the seat belt all the way out. But it can sometimes be only a temporary fix
    22nd June 2014
    174
    Oh I see, you're only spraying polish on the very end of the belt, the first part to "reel in".
    I think the previous owner of my car must have been a fan of fake tan, or was otherwise just a grubby bugger!
