Results 1 to 8 of 8
    VXRed blooded Robs-se's Avatar
    28th December 2012
    254
    Default Front suspension help
    Have put new shocks and springs on the front but now when driven it knocked land banged, what have I done wrong?
    Are you VXR enough? Andyb712's Avatar
    28th July 2018
    764
    Either you have not tightened something up or your top mounts are knackered
    But it could also be as simple as worn out drop links on the the front anti roll bar
    28th December 2012
    254
    New top mounts so possibly drop links as I didn’t put new ones on.
    28th July 2018
    764
    Probably is the droplinks then as you have replaced everything else it's probably finding the next weak link
    28th December 2012
    254
    Booked in now for mot so asked the garage to check it out, too sore now to muck about with it, had cracked ribs for last month or so
    11th July 2014
    366
    I changed drop links once and had knocking, turned out I hadn't tightened them enough.
    I had a knocking rear end recently that was resolved by changing ARB bushes.
    28th December 2012
    254
    All sorted, it was the nut at the top of the strut, I forgot to really tighten it, now have a mot and back on the road after 4 months on the drive
    Now to get rid of the damper error light on the dashboard.
    VXRed FinVectra's Avatar
    27th January 2014
    103
    Quote Originally Posted by Robs-se View Post
    Tech2 will help you with that
