Results 1 to 4 of 4
    28th January 2018
    8
    Default Corsa vxr ko4 turbo conversion help needed
    Ive read on here that you can fit astra vxr ko4 turbo onto a corsa vxr by using a corsa and astra vxr flange joined with pipes. Any one done it or be able to advise if it can be done. ive uploaded a pic of it that was on here https://www.google.co.uk/url?sa=i&rc...38507252691232
    16,904
    Just get an astra
    Yes was a common mod once upon a time for the corsa on here. Most used the dbilas manifold they made for the k04 corsa conversion.
    11th January 2006
    2,262
    i'd buy either the Courtenay manifold or the dbilas one if I was going to go ko4 route
    VXR enough Craig 522's Avatar
    12th February 2013
    2,160
    Personally I'd not go that route unless your engine is forged. Along with brakes/diff and all the other parts needed
    Just go stage 3 if you don't have all the above
    Sent from my SM-G920F using Tapatalk
