Results 11 to 20 of 30
  1. #11
    14th August 2018
    45
    Got it booked in for 29th
    See what they say 🙈
  2. #12
    14th August 2018
    45
    Well I finally got the car to vx dealer,
    Had a tech look at it, drive it and then I drove it.
    According to the tech guy the clutch click knock type sound when lifting the clutch pedal is normal and he says thereís nothing wrong with the duel mass
    The shudder is apparently where Iím changing gear to early in first.
    To his credit reving the car out slightly higher in first does stop the wired shudder I get during the gear change.
    So apparently I have to build more speed before shifting as thes sensors donít like me changing gear at anything between 1k and 3k rpm🤣
    And thereís me thinking I could in any car smoothly change gear at any rpm no matter how low
  3. #13
    VXRed blooded CoolStory's Avatar
    21st July 2018
    458
    Sorry but that sounds like the biggest load of bull Iíve ever heard. So now you have to over rev your car before changing gear so it doesnít judder?
    Something isnít right and the dealer needs to stop fobbing you off and sort it
  4. #14
    14th August 2018
    45
    The all got a bit edgy that it wasnít the dealer I bought it from who I took it to,
    Just the closest one,
    I had to wait 4 week for the opening as I needed a hire car.
    Maybe Iíll book it in with the dealer I got it from and see what they say.
  5. #15
    14th August 2018
    45
    Wanted 160£ to look at it
    I said mate this is a warrenty thing I got full vx warrenty when I got the car I ainít paying ****
  6. #16
    30th January 2016
    361
    Tbh mate, sorry to say this but that’s sounds like bull to me! Mine has no issues no matter what revs your at going from 1st to 2nd and any other gear fro that matter.
  7. #17
    VXRed blooded vocky's Avatar
    5th April 2015
    329
    Quote Originally Posted by Cossers View Post
    Mine has no issues no matter what revs your at going from 1st to 2nd and any other gear for that matter.
    as above, no issues at any revs - mine has zero judder
  8. #18
    14th August 2018
    45
    I had a play about on my way home from work
    I pulled away in first and when I got to 2k used my clutch and two bumps can be felt though the car
    Do it before 2k itís not so noticeable
    Above 2500k and itís not there
    No shifting just pushing in the clutch Pedal only does it in first
    I got to be honest guys Iím stumped
  9. #19
    13th October 2014
    367
    From how you describe it, sounds a bit different to the problem described in a document titled,
    '14-E-2638: F40 - Knocking noise at load reversal in all gears especially in 2nd and 3rd gear'
    if you Google it, but might be worth checking if your engine number was before or after improved clutches were fitted.
    I have not seen the clutch for the J VXR close up, but if I have got the part numbers/images right, appears the original part number 55581283 clutch had three damping springs,
    https://allegro.pl/astra-j-iv-opc-vx...614120246.html
    and the improved 55581284 clutch,
    https://www.bildelsbasen.se/se-sv/Op...2/OEM-P664291/
    has 6 damping springs, which looking closer at,
    http://img.euroauto.ru/photo/parts/u.../6915013/3.jpg
    appear to be double springs, all twelve of which must make a significant difference compared with what would appear to be just three springs in the original clutch friction plate.
    Can anyone who has taken a close look at the clutch correct or confirm any of this?
    Last edited by Carbon Flash; 31st October 2018 at 05:02 PM. Reason: corrections and additional URL and comments
  10. #20
    14th August 2018
    45
    So what your saying is if my clutch is early type the little clock I get whe lifting my clutch pedal and the bump I feel in first is or might be down to this bulliten?
    If so do I have a warranty claim as
    Clutches ainít covered
